Finished "movable tool table" from an idea shown by another builder. The table includes a drill press, buffer with Scotchbrite wheel, 1" belt sander, small vice, grinder/wire wheel, arbor press and small bending brake. Very convenient to access and number of tools in a small space (30"x36") and easy access from all sides. They can all be rolled away for easy storage. The base is a Harbor Freight Universal Metal Stand #46075 and Mobil Base #95288.
A change I would make is moving the electrical outlet up about 18"-24" above the table. This would allow coiled cords to be off the table making it easier to clean up debris.
Also added the vertical stabilizer to the wing storage rack as seen in Image 2. Had to remove the rudder, but that is small enough for easy storage on shelving.
